Beovox X25
Beovox X25
Beovox X25, X35 and X40 speakers were, at the time of their introduction, newly-developed speakers. The two speakers were very similar in appearance. Beovox X35 featured a 20cm bass unit and 2.5cm tweeter. Power handling capacity was 30 watts RMS. The cabinets measure 48cm high, 26cm wide and 18 [...]
Beovox X35 featured a 20cm bass unit and 2.5cm tweeter. Power handling capacity was 30 watts RMS. The cabinets measure 48cm high, 26cm wide and 18 cm deep. They had a built-in wall-mounting facility and were finished in a dark grey metallic effect.
Type Number: 6335
Release Date: 1983, 1984, 1985, 1986, 1987
Designer: Jacob Jensen
Colour / Finish: Grey
RMS power handling capacity 25 W
Music power handling capacity 35 W
Impedance: 8 ohms
Frequency response +4 -8 dB 55 – 20,000 Hz
Power at 96 dB SPL 6.3 W
Sensitivity 1 W 88 dB
Cabinet type Pressure chamber
Woofer: 16 cm
Tweeter: 6.6 cm
Net volume: 8.4 litre
Gross volume 12.4 litre
Dimensions W x H x D: 22 x 41 x 15cm
Weight: 4 kg
Downloads & Manuals
