Beovox S50
Beovox S50
Uncommon in the UK, the smallest of the range at the time and a two way speaker. Replaced by the S45 which was also downgraded in comparison with a captive lead.
Type Number: 6415
Release Date: 1980, 1981, 1982
Designer: Jacob Jensen
Colour / Finish: Teak, Rosewood
RMS power handling capacity 50 watts
Music power handling capacity 90 watts
Impedance: 8 ohms
Frequency response 4+ -8 dB 50 – 20,000 Hz
Frequency response +/- 4 dB 70 – 18,000 Hz
Sensitivity: 1W
Distortion 250 – 1000 Hz 1000 Hz <1%
Woofer: 21cm, throw +/- 3 mm
Tweeter: 2.5 cm dome
Net volume: 22 litre
Gross volume: 34 litre
Dimensions W x H x D: 26.5 x 53 x 26.5cm
Weight 8 kg
Downloads & Manuals
