BeoVox CX100
BeoVox CX100
Living proof that big sound need not take up more space than a couple of ring binders, Beovox CX50 snuggled in anywhere, even as extras in a Beolink® system. Beovox CX50 and Beovox CX100 loudspeakers were the smallest loudspeakers from Bang & Olufsen up to the time that the manufacture of passive [...]
Beovox CX50 and Beovox CX100 loudspeakers were the smallest loudspeakers from Bang & Olufsen up to the time that the manufacture of passive speakers ceased in 2002. They were mostly used to place within a passive Beolink® system (MCL), although they could also be used as main speakers. Thanks to different colour combinations they blended well into most people’s décor.
Beovox CX100 finally ceased production in September 2003 – the last of a long and successful line of passive speakers.
Description:
Passive loudspeaker, aluminium cabinet, available in black, white and brushed aluminium.
Replacement drive units: Top drive unit for CX50/CX100 Part number: 411743
Mounting Options
BeoVox CX50/CX100 replaced C40 and was designed to be optionally mounted with the wall brackets supplied in the box.
Type Number: 6343
Designer: Jacob Jensen
Colour / Finish: Grey, White, Aluminium
Impedance 6 ohms
Long-term maximum power 100 Watts
Effective frequency range* 64 - 20,000 Hz
Sensitivity 82 dB +/- 2 dB
Cabinet principle Closed box
Woofer 2 x 10 cm - 4"
Tweeter 2.5 cm - 1"
Net volume per channel 4 litres
Dimensions W x H x D/Weigth: 12 x 32 x 20.5 cm / 5 kg
Downloads & Manuals
