BeoVox 1001
BeoVox 1001
The Beovox 1001 was a very similar loudspeaker to the Beovox 1200 (Beosystem 1200 version), but to match the new black finish of the Beomaster 1001 the metal grille was made black. Sadly, the designers did not take the opportunity to fit a dome tweeter (as fitted to every other Beovox loudspeaker [...]
Sadly, the designers did not take the opportunity to fit a dome tweeter (as fitted to every other Beovox loudspeaker of the period), so the original (and outmoded) 2.5” cone type remained. As the Beomaster 1001 offered the facility of Ambiophonic stereo, 4 Beovox 1001s could be connected, and the model was also suggested for use with the Beogram 1500-1 record player.
Type Number: 6246
Release Date: 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978
Designer: Jacob Jensen
Colour / Finish: Teak, White, Rosewood
Dimensions: (HxWxD): 340 x 280 x 140mm
Power handling: 20W (40W peak)
Downloads & Manuals
