No image available
BeoVox 1
BeoVox 1 provides an elegant and discrete in-wall or in-ceiling two-way passive loudspeaker solution with excellent sound performance and numerous placement options in one solution. In the construction are selected high-quality loudspeaker units (one 16.5 cm woofer and one 2.5 cm tweeter) and app [...]
In the construction are selected high-quality loudspeaker units (one 16.5 cm woofer and one 2.5 cm tweeter) and applied a carefully designed cross-over network to improve its acoustic performance so the sound dispersion in the treble area is optimised.
Most in-wall loudspeakers are either round or square, but Bang & Olufsen has chosen the elegant, discrete, oval design for BeoVox 1 applying typical Bang & Olufsen craftsmanship. It will be available with either a white or black grille but at launch only the white version is available to order.
Many loudspeakers designed for installation in a wet environment may show an IP rating. This applies to products which can be dangerous to touch when water is in the vicinity because it may splash through the product surface and into the electronics. However, BeoVox1 is a product which is not directly connected to mains electricity so it may be installed directly over a bath or in a wet environment without the need to quote an IP rating.
Release Date: 2007
Colour / Finish: Black, White
Grille cover finish
White, black
Maximum input level
80 watts
Impedance
6 ohms
Effective Frequency range
50 – 20.000 Hz
Crossover frequency
3.000 Hz
Sensitivity
87 dB +/-2dB
Cabinet principle
Infinite baffle
Net volume, bass
18 litres if InWall cabinet is used
Magnetically shielded
No
Woofer
6½”
Tweeter
1”
Operation, Slide switch for treble damping
1: low, 2: medium, 3: maximum damping
Protection
Sealed for wet room use
Downloads & Manuals
