Beovision LX5000 Mk I Specifications
Picture tube (Visual picture): 63cm (59cm)
Picture tube system: flat square, Hi-Bri, In-Line 110 degrees
Contrast screen with metallised coating
Design: high format cabinet
Finish: Rosewood, white, grey metallic
Operation: Beolink 1000, one-way, Beolink 5000, two-way, Beolink 7000, two-way
TV tuner range: 46 – 855 MHz: VHF, S, Hyper, UHF channels
*(System I 470 – 855 MHz: UHF channels)
No. of TV programmes: 59 (+5 for local rooms)
Satellite identification: station naming/programme list
Satellite: *prepared for BeoSat LM
No. of satellite programmes: 99
Signal/noise level: > 35 dB/1 Vpp and antenna signal > 1mV
Crosstalk between sources: > 45 dB / 5 MHz
Teletext: FLOF, 6 alphabet; memory: 4 x 59 page nos
Sound system: *NICAM + A2 stereo decoder + A2 dual languages
Speaker system: 2 x bass reflex
Long-term max. output power: 2 x 40 W / 8 ohms
Harmonic distortion: < 0.5% at 15 W
Intermodulation: 50 dB weighted 50 mV (NICAM > 70 dB)
Frequency range, audio: 25 – 20,000 Hz +/- 1.5 dB
Power bandwidth: 25 – 20000 Hz
Channel separation A” stereo: >26 (NICAM > 50 dB)
Treble control: +/- 8 dB /10000 Hz
Crossover frequency: 2500 Hz
Power supply: 220 – 240 V
Power consumption: 100 (75 – 165) W
Power consumption stand-by: 3 W
Dimensions W x H x D: 78 x 47 x 42cm
Weight: 36.5 kg
Connections: AV1 & AV2, S-VHS, Power Link 1 & 2, Audio Aux Link, External speakers L & R, Headphone, B&O stand
Link compatibility: Datalink
Beovision LX5000 Mk II Specifications
Picture tube (Visual picture) 63cm (59cm)
Picture tube system Flat square, Black Line, Black matrix, In-Line 110 degrees
Cabinet Rosewood, White, Black, Blue, Grey
Crossover frequency 3200 Hz
Power supply: 230 volts
Power consumption: 95 (75 – 200) W
Power consumption stand-by: 3.5 W
Weight: 36.5 kg
