BeoVision Eclipse 55
Our goal with Beovision Eclipse was crystal clear: merge images so lifelike they almost seem unreal with sounds so powerful they literally break out of the picture. No easy task, but the result is quite simple: we designed the definitive TV. All-in-one music system Beovision Eclipse has a three- [...]
Beovision Eclipse has a three-channel sound system, providing the ability to deliver speech-optimised centre channel audio as well as powerful stereo performance.
Clear-cut visions
A sharp, black glass screen cutting straight through an organic aluminium body. It’s a bold and clear design statement of picture and sound in perfect alignment.
See what the world’s best TV sound will do for your movies
Powerful enough to compete with many stand-alone music systems, a Beovision TV is the centre of any luxury home cinema experience. Learn how to get the most out of its truly impressive capabilities.
Statement design
Any way you look at it; from the front, the side or from the rear, Beovision Eclipse looks stunning. Every little detail is carefully attended to and our use of high-quality Materials provides the aesthetic freedom to place the TV anywhere you want.
Picture, pitch black
The OLED screen technology brings you a whole new TV experience thanks to more than 8 million self-lit pixels. Enjoy the deepest blacks, richest colours and realistic picture quality. The most important aspect of your viewing experience.
Sound, pitch perfect
The integrated speaker system holds a powerful 450 watts 3-channel setup with the ability to outperform even the most potent soundbar on the market. Expect an exceptional sound performance that brings your viewing experience to a new and exciting level.
Connectivity
For your listening pleasure, Beovision Eclipse supports music streaming via Apple AirPlay , Bluetooth and Google Cast. It integrates seamlessly with other Multiroom products letting you customise and expand your entire home music experience.
Controls
Your TV experience has never been as easy or as personal as this. Escape the constraints of flow TV and dive straight into your favourite content with a single click. The world’s premier Smart TV platform, webOS, just keeps getting smarter.
Loudspeaker
Integrated fully active three channel stereo (centre and stereo)
Amplifier
1 x 50 watts for centre tweeter 2 x 50 watts for fullrange driver 3 x 100 watts for midrange/woofer
Speaker Configuration
1 x 1″ tweeter 2 x 2.5″ fullrange drivers 3 x 4″ midrange/woofer
Advanced Sound Features
Integrated 7.1 surround sound module Adaptive Bass Linearisation Sound modes and Speaker groups TrueImage up and downmixing Immaculate Wireless Sound integrated for a full wireless surround solution with connection of up to 8 speakers
Frequency Range
29Hz – 22,000 Hz
Sound format HDMI A-D
Dolby Digital 5.1 Dolby Digital plus 7.1 DTS HD-Master Audio 7.1 and the underlying DTS formats PCM 7.1 multichannel
Customizable Sound EQ
9 editable sound modes on Bang & Olufsen app
Speaker groups
Yes
Display Type
4K OLED Perfect black & Wide viewing angle
Display Resolution (H x V, Pixels)
3840 x 2160 Over 8M pixels
HDR
HDR 10 HDR 10 Pro HLG Dolby Vision IQ
Codecs compatibility
HEVC VP9 AV1
Gaming
< 1 ms response time Input lag 12,8 ms VRR G-sync and FreeSync™ compatible ALLM
4k and 2K HFR HGiG mode
Smart TV
webOS
Remote controls
2way Bluetooth control via Beoremote One BT
Streaming services
Apple AirPlay Bluetooth Google Cast Beolink Multiroom Spotify Connect
Integrated music services
Deezer (incl Deezer HiFi) TuneIn internet radio QPlay (China specific)
Inputs
Soundcenter: 4 x HDMI (2.0) 1 x Ethernet 10/100Mb 1 x Analogue line in (3,5 mm mini jack) 1 x Optical in
TV screen: 4 x HDMI (2.1) 3 x USB 1 x Ethernet 10/100Mb
Outputs
8x WiSA 8x Powerlink 6x PUC control via IR
Internal Connection
1 x HDMI (2.0) eARC 1 x Ethernet 10/100Mb
Peripheral Unit Control
Integrated Peripheral Unit/Set-top Box Controller controlling six units, allowing you to control set-top boxes with the Bang & Olufsen remote control
Wireless Speaker Connectivity
Standard built-in, WiSA compliant Connect up to eight BeoLab speakers wirelessly in addition to the wired speakers
Bluetooth Version
Bluetooth 4.2
Wi-Fi
Dual-Band Wi-Fi (2.4 & 5 GHz) IEEE 802.11 b/g/n/ac
Materials
Aluminium Oak wood Smoked Oak wood Walnut wood Fabric
Placement Options
Motorised floor stand +/- 90° rotation Floor stand Motorised wall bracket with remote operation (60° rotation) Manual wall bracket with right/left turn (60°rotation)
Weight
55″: 43,3 kg 65″: 52,2 kg Floor stand 25,2 kg Wall bracket: 8 kg
Dimensions (cm)
55″ floor standing: 123.5 h x 139 w x 37.2 d cm 55″ wall bracket: 99.5 h x 139 w x 12.2 d x 124.9 opening depth cm
65″ floor standing: 136 h x 161.1 w x 51.8 d cm 65″ wall bracket: 111.8 h x 161.1 w x 12.2 d x 144.1 opening depth cm
Power Consumption
Typical: 80 W (Soundcenter)
Energy Efficiency Class
65″: G 55″: G
Mains Voltage Range
100~240 Vac 50-60Hz
Downloads & Manuals
