BeoVision 1
BeoVision 1
BeoVision 1 is definitely a case of less being more. BeoVision 1 takes television back to basics. Gone is anything that could complicate or confuse, and what’s left is the simple enjoyment of watching TV. At the heart of BeoVision 1 is a four-buttoned remote control and a ground-breaking method of o [...]
BeoVision 1 is definitely a case of less being more. BeoVision 1 takes television back to basics. Gone is anything that could complicate or confuse, and what’s left is the simple enjoyment of watching TV. At the heart of BeoVision 1 is a four-buttoned remote control and a ground-breaking method of operation. Each family member can establish their own group of favourite channels which are easily accessed and edited via the Beo1.
BeoVision 1 LS
BeoVision 1 LS is a variant of the BeoVision 1 television, and has been specially developed to interact with Bang & Olufsen’s Beolink® system. With its many colour and placement options, BeoVision 1 LS can be located in the bedroom, study or home office, and – via a MasterLink cable – give you access and control of all the sources in your main room set-up. With functions similar to the BeoVision MX 4002, the BeoVision 1 LS can only be controlled with the Beolink® system remote control, Beo4. The group function of BeoVision 1 and its optional STB, Sat-Receiver and DVD Controller are not available in the Beolink® compatible version.
Simplicity
BeoVision 1 cleans up the technological mess and takes television back to basics. Gone is anything that complicates or confuses and what’s left is the pure and simple enjoyment of watching television.
Menus
Just as BeoVision 1 doesn’t look like any other television, it doesn’t act like it either. With a Beo1 in hand, the user interacts with a series of specially created on-screen menus to offer a uniquely simplified method of operation. In a world of unlimited TV channels and endless options, BeoVision 1 puts you back in charge of your television. Instead of zapping through all that’s on offer, you organise the channels you want in up to 8 user groups; News, Movies, Sports – or perhaps one for each member of the family.
Performance
Into a world where complexity is often mistaken for progress comes BeoVision 1. A straightforward, easy-to-use television with a first-rate picture, a sumptuous sound reproduction, and ground-breaking operation principle. Instead of zapping through endless lists of programmes, BeoVision 1 offers instant access to an individual choice of programmes in up to eight user groups; News, Movies, Sports, Children etc. – or perhaps one for each member of the family
Placement
When it comes to placement options, BeoVision 1 spoils you with choice. Easy access, anywhere you want it, BeoVision 1 offers a range of five placement options, from table top to high and low floor stands, from wall mounting to a traditional stand with room for a VCR player. If you opt for wall mounting or the high stand, the power and aerial cables can be hidden inside the stand for seamless connection. Place it on a table with or without room for a VCR/DVD player. Or set it upon the special high stand and lift your television 2 metres off the ground.
Turning Function
Are you tired of rearranging the furniture to suit the TV? With the optional turning function, BeoVision 1 will turn through an arc of 70 degrees. You can program it to turn towards you every time you sit down in your favourite viewing chair and switch on.
Physical design
From front to back, from start to finish – BeoVision 1 is a true reflection of Bang & Olufsen’s belief in combining unrivalled technology with emotional appeal.
You can see it in the clear, simple design that stands out but never dominates. In the choice of vivid colours that includes yellow, blue, green, red, grey and black and special mat finish that covers the entire cabinet. Or in the cantilevered front screen that appears to float by itself. It’s an effective blend of form and function that creates its own unique experience. Because BeoVision 1 brings television out into the open, it’s important that it looks good from every angle. That’s why the coloured surface, with its unique silk mat texture, covers the entire cabinet; from top to bottom and front to back.
As from October 2002, both BeoVision 1 and Beocenter 1 were delivered with a Beo4 remote control in place of Beo1 which was discontinued. By January 2003 a Dolby Digital Surround Sound kit was available for both TV models. The colour range of BeoVision 1 was reduced to two colours: black and grey.
Sound & picture
It’s one of the most impressive things about BeoVision 1 – and something you’ll probably never notice. While you’re watching what’s on the screen, it’s constantly monitoring the picture and sound being produced. It will react instantly to the slightest change in the surrounding light and even take account of the sound variations that occur when you switch from one channel to another. It’s total sound and picture quality – take it for granted. Bang & Olufsen realised long ago that sound makes the best picture even better. That’s why BeoVision 1 uses powerful active loudspeakers to give the purest sound possible. BeoVision 1 also automatically adjusts and optimises the sound level when you switch between different TV channels.
A TV picture placed high above the rest so that everyone can see it is not a new idea. It has been around for a long time, but only seen in direct context with a wall. The picture was seen placed on a shelf, a wall bracket or occasionally suspended from a ceiling.
BeoVision 1 and Beocenter 1 are designed to be seen from all sides. Designed to stand like sculpture in the centre of a room. The ideas team therefore wished them to be mounted as high as possible in the room, or even out in the open under the open sky, if possible.
Just looking at BeoVision 1 or Beocenter 1 on its tall stand may not reveal the inspiration behind the solution but it is obvious when you hear it.
In the latter stages of development of BeoVision 1, David Lewis presented his idea to the tram: “We’ll create a ‘banner’ as in medieval times, when a knight would carry his coat of arms, embroidered onto a piece of cloth and raised high on a pole, so that everyone could see where he was”.
VisionClear
BeoVision 1 offers the sharpest, clearest picture ever seen from a Bang & Olufsen television. And to make sure you experience it every time you watch TV, BeoVision 1 uses the latest VisionClear technology to automatically optimize brightness, contrast and colour to match the prevailing light conditions in the room.
Intelligent TV
Take television back to its basic essentials; the enjoyment of a sound and picture experience – a simple intelligent television.
BeoVision 1 cuts down on the superfluous functions that have little relevance to watching television and greatly enhances those that do. With both picture and sound optimised automatically, you’ve even more freedom to focus on the things that really matter; pure, unadulterated entertainment.
BeoVision 1 LS
If you already have Bang & Olufsen equipment in your living room, you can opt for the Beolink® version of BeoVision 1 and place it in the study or bedroom. From there you can access the radio or CD on your CD player, or enjoy the extra video options of your main room setup.
BeoVision 1 LS – Press Release 2000
Two concepts united in new TV. The unity of two groundbreaking concepts is the idea behind the introduction of the newest member of the Bang & Olufsen video family. The BeoVision 1 link slave variant (LS) combines the logical distribution of sound and picture known from the Beolink® system with the simplicity of the BeoVision 1 concept. The prospects look bright for the newest video product from the factory in Struer.
“With the BeoVision 1 link slave variant, we offer a complement to the already successful BeoVision MX4002 television. Whereas the classic styling and dimensions of MX4002 will continue to appeal to several thousand customers annually, we believe that the BeoVision 1 LS will only serve to increase these numbers”, states Product Manager Dirk Hogenfeld.
“This variant simply provides an additional choice for the consumer who wishes to expand his or her Beolink® system. Emotionally, he or she may choose from the discreet elegance of the MX line or the soft refinement of BeoVision 1 LS. From a purely physical aspect, he or she now has the freedom to choose between the charming 21″ screen of MX4002 or the attractive 25″ screen of the BeoVision 1 LS with all the placement options”, continues Hogenfeld.
BeoVision 1 LS’s flexibility stems primarily from a choice of five unique placement possibilities: from floating almost magically out from the wall, to sitting on a more traditional floor stand, to standing tall on a 160 cm column. Utilising the optional built-in motor, the BeoVision 1 LS can also be turned to face in different directions.
Externally, BeoVision 1 LS offers a truly colourful experience. It is available in six different colours: green, black, yellow, blue, red and grey. And all with matching fabric in the V-shape below the TV screen. This finishing touch helps ensure that the BeoVision 1 LS blends into any home interior.
Furthermore, a TV that goes anywhere also needs to produce a picture that looks good anywhere. The BeoVision 1 LS’s automatic contrast, brightness and colour control means superb picture quality in more or less any light. Add the optional anti-reflection coated contrast glass to the 25″, 4:3 format screen, and the amount of incoming light is reduced by almost 99%, when compared with ordinary front glass.
Access to all main room sources
Like all other dedicated Beolink® products, only one simple press on the Beo4 remote control is necessary to access a main room source – such as CD, radio, videotape or DVD. Volume control takes place independently of the main room. The operation principles are logical and consistent with remainder of the Bang & Olufsen product portfolio.
Type Number: 8600, 8602, 8603, 8605, 8606, 8608, 8610, 8612, 8613, 8615, 8616, 8618, 8620, 8622, 8623, 8628, 8662, 8663, 8665, 8666, 8668, 8684, 8625.8626
Release Date: 2000, 2001, 2002, 2003, 2004, 2005, 2006
Designer: David Lewis
BeoVision 1LS Specifications
Types:
NEU 8600 (1999 – Aug 2000)
HK 8602 (2000)
GB 8603 (1999 – Aug 2000)
AUS 8605 (2000 – Aug 2000)
SNG 8606 (2000 – Aug 2000)
F- GB 8608 (2000 – Aug 2000)
Terminal included: Beo1
Stand turning function: +/- 35 degrees, remote operated.
Picture tube: 63 cm (4:3)
Contrast screen: Grey glass
VisionClear:
Auto picture adjustment
Auto cut-off
CTI
Adaptive Luminance Peaking
Scan Velocity Modulation
Teletext:
Improved Teletext
9 memory pages per programme
CTV system according to type:
B/G/D/K/I/L/L’/M,
PAL/SECAM, NTSC on AV
Tuner range: 45 – 860 MHz, VHF band I-III, S, Hyper, UHF
Pretuned TV programmes: 99
Stereo decoders: A2 + NICAM
Speakers:
Power amplifier modules: 4 units
Frequency range: 50 – 20,000 Hz
Max. sound pressure level: 96 dB
Cabinet principle / Net volume: Bass Reflex / 2.8 litres
Woofer: 115 mm – 4 1/2″
Tweeter: 18 mm – 3/4″
Bass equalizer: Adaptive
Magnetic shielded: Yes
Connections for external sources:
VTAPE-AV-Decoder: 2 x 21-pin for V.TAPE, A/V or Decoder. RGB and S-Video in.
Camcorder / Auxiliary: 3 x phono sockets (video in/audio L-R in)
Headphone socket: Mini jack
Satellite module
Tuner range: 950 – 2150 MHz
Programmes: 198 TV/Radio
Sound systems: Mono/Stereo
Satellite radio: Yes
Down conv. Supply:
14/18 volts control, Tone control (22 kHz)
DiSEqC (One way control)
Connections: 1 x F-connecter
Optional extra:
Satellite module 4190
Set-top box Controller 4195
System Modulator EU 4016
System Modulator GB 4018
Master Link module 4015
Power Link module 4017
Motor Kit 4193
Dimensions W x H x D / Weight: 61 x 73 x 42 cm / 37.6 kg
Cabinet finish: Silk matt; black, blue, yellow, red, green, grey
Power consumption: Typical 81 watts, standby < 0.5 watts
Stands:
Type No. 4185 Table stand
Type No. 4186 Floor stand, low
Type No. 4187 Floor stand, high
Type No. 4188 Wall bracket
Type No. 4189 Video stand high Gloss Black
Set-top Box Controller: Type No. 4195
*Only in connection with ordering BeoVision 1
Types:
NEU 8650 (Sept 2000 – Sept 2001)
HK 8652 (Sept 2000 – Sept 2001)
GB 8653 (Sept 2000 – Sept 2001)
I 8654 (Sept 2000 – Sept 2001)
AUS 8655 (Sept 2000 – Sept 2001)
SNG 8656 (Sept 2000 – Sept 2001)
F- GB 8658 (Sept 2000 – Sept 2001)
Stand turning function: +-35 degrees
Picture tube/Visual picture: 63cm (4:3), Black line, Black Matrix
Contrast screen: grey glass
VisionClear: auto picture adjustment
Auto cut-off; CTI
Teletext Improved Teletext
CTV system According to type: B/G/D/K/I/L/L’/M, PAL/SECAM, NTSC on AV
Tuner range: 45- 860 Mhz, VHF band I-III, S, Hyper, UHF
Pre-tuned TV programmes: 99, auto-naming
Stereo decoders A2 + NICAM
Speakers:
Frequency range: 50-20.000 Hz
Max sound pressure level: 96 dB
Cabinet principle/Net volume: bass Reflex/2.6 litre
Woofer: 115mm
Tweeter: 18mm
Bass equalizer: adaptive
Magnetic shielded: yes
Connections:
TV Input Aerial, 1 x 75 ohms
V.Tape – AV/Decoder 2 x 21-pin for V.TAPE, A/V or Decoder. RGB and S-Video in
Camcorder/Auxiliary 3 x phono sockets (video in/audio L-R in)
Headphone socket: mini jack
Beolink 1 x Master Link, as Link slave only
Optional features/modules:
Antireflection coated contrast screen (*) 4192
Motor Kit 4012
Dimensions W x H x D/Weight: 61 x 73 x 42cm/ 38 kg
Cabinet finish Black, Blue, Yellow, Grey, Red, Green
Power consumption Typical 81 W, standby: < 1,2 W
(*) Only available factory-fitted
Stands: Type: Height, incl. TV
Table stand: 4185 82cm
Floor stand, low: 4186 105cm
Wall bracket: 4188 80cm
Video stand: 4189, High Gloss Black 119cm
Floor stand, high: 4187 (plate)
4194: (base)
4199: (tube) 231cm
Market specifications:
Market: Type: Country: CTV system
NEU 8650 A-B-CH-D-DK-E-GR-N-NL-P-S-SF-Other B/G
HK 8652 HK D/K/M/I
GB 8653 GB I
I 8654 I B/G
AUS 8655 AUS B/G
SNG 8656 SNG, EEU B/G/D/K
F-GB 8558 F-CH B/G/L/L’/I
BeoVision 1L (2001) Specifications
Types:
NEU
HK 8662
GB I 8663 8684
AUS 8665
SNG 8666
F- GB 8668
Picture tube/Visual picture: 63 cm (4:3), Black line, Black Matrix
VisionClear: Auto picture adjustment
Auto cut-off
CTI
Teletext: Improved Teletext
CTV system: according to type: B/G/D/K/I/L/L´/M, PAL/SECAM, NTSC on AV
Tuner range: 45- 860 MHz, VHF band I-III, S, Hyper, UHF
Pre-tuned TV programmes: 99, auto naming
8 Programme Groups
Speakers:
Power amplifier modules 4 units
Frequency range: 50-20000 Hz
Cabinet principle/Net volume: Bass Reflex/2.6 litre
Woofer: 115 mm
Tweeter: 18 mm
Satellite module
Satellite radio: yes
Down conv. supply: 14/18 V control, Tone Control (22 KHz)
Connections 1 x F-connecter
Connections: Input TV Aerial, 1 x 75 ohms
Master Link: 1 x Master Link
Power Link (Optional): 2 x 8-pin sockets
Satellite (Optional): 1 x F-connecter
Set-top box Controller (Optional): mini jack
System modulator (Optional): 1 x 75 ohm aerial male (Splitter/System modulator Output)
Optional features/modules: Satellite module 4190
Set-top box Controller: 4195
Power Link Module: 4017
Motor kit: 4193
System Modulator: EU 4016
System Modulator: GB 4018
Stands: Type: Height, incl. TV Diameter, plate
Table stand 4185 82cm 29,5cm
Floor stand, low 4186 105 cm 44cm
Wall bracket 4188 80cm
Video stand 4189, High Gloss Black 119cm
Floor stand, high 4187 (plate)
4194 (base) 60cm
4199 (tube) 231cm
Cabinet finish: black, blue, yellow, grey, red, green.
Power consumption Typical 81 W, Standby:.< 1,2 W
Market: Type: Country: Active CTV system Basic CTV system *) System modulator
NEU 8660 A-B-CH-D-DK-E-GR-I-N-NL-P-S-SF-Other B/G B/G G
HK 8662 HK D/K/M/I B/G/L/D/K/M/I I
GB 8663 GB I B/G/L/L’/I/D/K I
I 8664 I B/G B/G G
AUS 8665 AUS B/G B/G G
SNG 8666 SNG, EEU B/G/D/K B/G/L/L’/I/D/K G
F-GB 8668 F-CH B/G/L/L’/I B/G/L/L’/I/D/K G
*) Basic CTV systems can be switched ON in Service menu.
BeoVision 1 (Update I – 2000)
BeoVision 1 (Update II – 2001)
Types:
NEU 8610
HK 8612
GB 8613
AUS 8615
SNG 8616
F- GB 8618
Auto cut-off
CTI
8 Programme Groups
Speakers:
Woofer: 115 mm
Tweeter: 18 mm
Satellite module:
Down conv. supply: 14/18 V control, Tone Control (22 Khz)
Connections:
TV Input: aerial, 1 x 75 ohms
Camcorder/Auxiliary: 3 x phono sockets (video in/audio L-R in)
Satellite module: 4190
Antireflection coated contrast screen *: 4192
Motor Kit: 4193
DVD Controller, Beo4 recommended: 4020 (EU)
4021 (GB)
4022 (AUS)
*) Only available factory fitted
Table stand 4185 82 cm
Wall bracket 4188 80 cm
Video stand 4189, High Gloss Black 119 cm
4194 (base)
4199 (tube) 231cm
Dimensions W x H x D/Weight: 61 x 73 x 42 cm/ 38 kg
Power consumption Typical 81 W, Standby: < 0,5 W
NEU 8610 A-B-CH-D-DK-E-GR-I-N-NL-P-S-SF-Other B/G B/G
HK 8612 HK D/K/M/I B/G/L/D/K/M/I
GB 8613 GB I B/G/L/L’/I/D/K
AUS 8615 AUS B/G B/G
SNG 8616 SNG, EEU B/G/D/K B/G/L/L’/I/D/K
F-GB 8518 F-CH B/G/L/L’/I B/G/L/L’/I/D/K
Types:
NEU 8620
HK 8622
GB 8623
AUS 8625
SNG 8626
F- GB 8628
Picture tube/Visual picture: 63 cm (4:3) /60cm, Black line, Black Matrix
Auto cut-off
CTI
CTV system According to type: B/G/D/K/I/L/L´/M, PAL/SECAM, NTSC on AV
Tuner range 45- 860 MHz, VHF band I-III, S, Hyper, UHF
8 Programme Groups
Speakers:
Woofer: 115 mm
Tweeter: 18 mm
Satellite module:
Down conv. supply 14/18 V control, Tone Control (22 KHz)
Connections: Input TV Ariel, 2 x 75 ohms
V.Tape – AV/Decoder 2 x 21-pin for V.TAPE, A/V or Decoder. RGB and S-Video in.
Headphone socket: mni jack
Master Link (Optional): 1 x Master Link
System modulator (Optional): 1 x 75 ohm aerial male (Splitter/System modulator Output).
Motor Kit 4193
4194 (base)
4199 (tube) 231 cm
NEU 8620 A-B-CH-D-DK-E-GR-I-N-NL-P-S-SF-Other B/G B/G G
HK 8622 HK D/K/M/I B/G/L/D/K/M/I I
GB 8623 GB I B/G/L/L’/I/D/K I
AUS 8625 AUS B/G B/G G
SNG 8626 SNG, EEU B/G/D/K B/G/L/L’/I/D/K G
F-GB 8628 F-CH B/G/L/L’/I B/G/L/L’/I/D/K G
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoVision 1
861x, 865x, 85xxService ManualSilver Log in
BeoVision 1
Instruction BookSilver Log in
BeoVision 1
BeoVision 1
8600, 8602, 8603, 8605, 8606, 8608Service ManualSilver Log in
BeoVision 1
8630, 8632, 8633, 8635, 8636, 8638Service ManualSilver Log in
BeoVision 1
4185Instruction BookSilver Log in
BeoVision 1
4186Instruction BookSilver Log in
BeoVision 1
4187Instruction BookSilver Log in
BeoVision 1
4188Instruction BookSilver Log in
BeoVision 1
4189Instruction BookSilver Log in
BeoVision 1
863x, 852xService ManualSilver Log in
BeoVision 1
862x, 866x, 851xService ManualSilver Log in
BeoVision 1
8610, 8612, 8613, 8615, 8616, 8618, 8650, 8652, 8653, 8654, 8655, 8656, 8658Service ManualSilver Log in
BeoVision 1
BeoVision 1
BeoVision 1
