Beomaster 1600 Type 1703 could be made up as part of Beosystem 1600, when linked together with other compatible Bang & Olufsen products such as Beocord 1600 and Beogram 1600. FM only version of the 1700 and not seen in the UK.
BeoMaster 1600 (1980)
Frequency response: 20 – 20,000 Hz
Minimum continuous RMS power per channel: 20 W at 4 ohms
20 W at 8 ohms
Speaker impedance: minimum 4 ohms
Maximum total harmonic distortion: < 0.4 %
IHF Intermodulation: < 0.2 %
Bass control response at 40 Hz: +/- 11 dB
Treble control response at 12,500 Hz: +/- 11 dB
RIAA amplifier: built-in
FM range 87.5 – 108 MHz
Power supply:
1702 220V
1703 120V
Dimensions: 60.3 x 9.5 x 24.1cm
Weight: 8.5 kg
Connections: Phono DIN, tape DIN, speakers: 2 sets
Downloads & Manuals
Documents & Downloads
Document | Type No. | Type | Required | Action |
BeoMaster 1600 (1980) | 1702, 1703 | Service Manual | Silver | Log in |
Photo Gallery
No gallery images.
