BeoMaster 1500
BeoMaster 1500
Beomaster 1500 was a compact combination of an AM/FM radio and a 2 x 25 watts RMS hi-fi amplifier. Four FM stations could be pre-set and tuning accuracy for all three wavebands was aided by an illuminated indicator and combined AFC/ST circuit. There were connections for a cassette deck, record playe [...]
Beomaster 1500 was a compact combination of an AM/FM radio and a 2 x 25 watts RMS hi-fi amplifier. Four FM stations could be pre-set and tuning accuracy for all three wavebands was aided by an illuminated indicator and combined AFC/ST circuit. There were connections for a cassette deck, record player, headphones and two pairs of stereo speakers.
This was Bang & Olufsen’s smallest receiver (1979 – 80) but in terms of quality and performance data it matched their top model, Beomaster 4400 in many respects – thus offering the same high standards of electronic engineering to those who demand excellence but require less power and fewer facilities. Beomaster 1500 therefore represented extremely good value.
Beomaster 1500 could be made up as part of the Beosystem 1500 when linked together with other compatible Bang & Olufsen products.
Type Number: 2629
Release Date: 1978, 1979, 1980
Designer: Jacob Jensen
Colour / Finish: Rosewood, Teak
Power output RMS DIN:2 x 25 W / 4 ohms
2 x 20 W / 8 ohms
Harmonic distortion: < 0.1 %
Intermodulation: < 0.15 %
Frequency range: 20 – 30,000 Hz
FM tuner range: FM 87.5 – 108 MHz
LW: 150 – 350 kHz
MW: 520 – 1610 kHz
Power supply / max. consumption: 110 – 130 – 220 – 240 V / 150W
Dimensions W x H x D: 50 x 9 x 27cm
Weight: 9 kg
Connections: Tape DIN, gramophone DIN, headphone jack
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoMaster 1500
2629Service ManualSilver Log in
