BeoMaster 1000
BeoMaster 1000
Beomaster 1000 – a compact all-transistor hi-fi 2 x 15 watt stereo amplifier equipped with a highly selective FL radio with extended FM band (to 108 MHz), 3-gang tuning capacitor and 4-stage intermediate-frequency amplifier, automatic control circuit which locks on FM stations and keeps them accurat [...]
Beomaster 1000 – a compact all-transistor hi-fi 2 x 15 watt stereo amplifier equipped with a highly selective FL radio with extended FM band (to 108 MHz), 3-gang tuning capacitor and 4-stage intermediate-frequency amplifier, automatic control circuit which locks on FM stations and keeps them accurately tuned.
It is prepared for single-transmitter stereo broadcasts, having a B&O multiplex adaptor (stereo decoder); it is also equipped with a pilot lamp (“Beo-Beacon”) which lights up when the receiver is tuned to a station transmitting an FM stereo programme.
The stereo amplifier, which plays both stereo and mono gramophone records, delivers no less than 2 x 15 watts of power output; piano-key speaker change-over switches which control two sets of stereo speaker systems, separate extra-efficient bass and treble controls; balance control for correct stereo sound distribution; physiologically compensated volume control (provides full balance at all volume levels throughout the tonal range); separate scratch and rumble filters; piano-key switching between mono and stereo reproduction; piano-key selectors for switching between the following types of operation: FM Broadcasting, FM Automatic Frequency Control; Tape Recorder; Gramophone 1; Gramophone 2.
Dimensions: 87mm high, 505mm wide, 24mm deep.
Choice of teak or Brazilian rosewood finish. Awarded the 1966 iF Prize for Industrial Design”
Type Number: 2302, 2304, 2317, 2318
Release Date: 1964, 1965, 1966, 1967, 1968, 1969, 1970
Colour / Finish: Teak, Rosewood, Oak, White
Power output: 2 x 15 W continuous
2 x 20 W music power
Frequency range 30 – 25,000 Hz- +/- 2 dB
Distortion <1% at 40 Hz – 1 kHz – 12.5 kHz / 15 W
Tone controls:
Bass control: + 10 dB – 17 dB at 60 Hz
Treble control: + 12 dB – 16 dB at 12.5 kHz
Built-in stereo decoder Only type 2317
Wave bands:
FM 88 – 108 MHZ
RIAA amplifier: Built-in
Voltage: 110 – 130 – 220 – 240 V
Power consumption 20 – 120 W
Dimensions H x W x D: 9 x 51 x 24cm
Weight 5.5 kg
Connections: Gramophone 1
Gramophone 2
Tape
Aerial
Speakers 2 sets
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoMaster 1000
0001SchematicSilver Log in
BeoMaster 1000
BeoMaster 1000
2302, 2304Service ManualSilver Log in
BeoMaster 1000
2313, 2314Service ManualSilver Log in
BeoMaster 1000
2316, 2317Service ManualSilver Log in
