BeoGram RX
BeoGram RX
A basic radial armed turntable which replaced the Beogram 1800 in the range. It was designed for use with other makes of amplifier and hence was fitted with phono plugs instead of the more usual, for B&O, Din plug. It came without a MMC pick up though most would be fitted with a MMC5.
Type Number: 5771, 5773
Release Date: 1983, 1984, 1985, 1986
Designer: Jacob Jensen
Colour / Finish: Silver
Cartridge Type: MMC5
Pickup MMC 1-5
Wow and flutter, DIN 62 dB
Rumble DIN unweighted > 42 dB
Speeds 33 – 45 rpm
Speed deviation < +/- 0.2 %
Power supply:
5771: 220V
5773: 120V
Power consumption: 8 W
Dimensions W x H x D: 44.5 x 20.5 x 33cm
Weight 6 kg
Downloads & Manuals
