BeoGram CDX 2
BeoGram CDX 2
This advanced CD player was straight from tomorrow's world - but it would still marry up happily with any Bang & Olufsen system created over the previous decade. It was as simple to use as a tape recorder. The track search system was invaluable for finding your way quickly around the disc. A dis [...]
This advanced CD player was straight from tomorrow's world - but it would still marry up happily with any Bang & Olufsen system created over the previous decade. It was as simple to use as a tape recorder. The track search system was invaluable for finding your way quickly around the disc. A display indicated the number of the track you're on.
Recording was just as straight forward. And you could time recordings to the second - just press the sensi-touch panel and you could find out how much time was left on a particular track or on the whole disc.
This replacement for the former Beogram CDX used at that time, new 16-bit technology and an all-new optical system. The player itself though, was derived from the Philips CD150 machine; the same as that in the Beocenter 9000. After one year the machine was discontinued and replaced by the Beogram CD 3300 - a similar sensi-touch CD player - as part of Beosystem 3300.
Type Number: 5161, 5162
Release Date: 1988, 1989, 1990
Designer: Jacob Jensen
Colour / Finish: Black, Silver
Frequency range: 3 – 20,000 Hz +/- 0.3 dB
Signal-to-noise ratio: > 96 dB / 100 dB A-weighted
Dynamic range: > 96 dB
Harmonic distortion incl. noise: < 0.003% at 0 dB; 94 dB
Channel difference: 20,000 Hz > 50 dB
Phase error between L and R 0 degree at 20 – 20,000 Hz
Output analogue: 2 V RMS at 0 dB
Output, signal: for digital equipment
Power supply:
5161: 220V
5162: 240V
Power consumption 30 W
Dimensions W x H x D: 42 x 7.5 x 31cm
Weight 4.9 kg
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoGram CDX 2
5161, 5162, 5164Service ManualSilver Log in
