BeoGram CD 3300
BeoGram CD 3300
It's a fact that not all compact disc players are ideal for all types of music. Some of them seem to highlight certain parts of the frequency range. But you can be confident that Bang & Olufsen's CD players never discriminate between rock and roll and classical. They smooth over faults in the CD [...]
It's a fact that not all compact disc players are ideal for all types of music. Some of them seem to highlight certain parts of the frequency range. But you can be confident that Bang & Olufsen's CD players never discriminate between rock and roll and classical. They smooth over faults in the CD very cleverly too, because not all compact discs are perfect. So it's just as well that Bang & Olufsen CD players are!
Beogram CD 3300 was part of Beosystem 3300 although it could have been used as a stand-alone item.
Type Number: 5141, 5142, 5143, 5145
Release Date: 1987, 1989, 1990
Designer: Jacob Jensen
Colour / Finish: Grey
Beolink: DataLink
Frequency range: 3 – 20,000 Hz +/- 0.3 dB
Signal-to-noise ratio: > 96 dB / 100 dB A-weighted
Dynamic range: > 96 dB
Harmonic distortion incl. noise < 0.003% at 0 dB;
94 dB
Channel difference: 20,000 Hz > 50 dB
Phase error between L and R 0 degree at 20 – 20,000 Hz
Output analogue: 2 V RMS at 0 dB
Power supply:
5141: 220V
5142: 240V
5143: 120V
5145: 240V
Power consumption: 30 W
Dimensions W x H x D: 42 x 7.5 x 31cm
Weight: 4.9 kg
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoGram CD 3300
Service ManualSilver Log in
BeoGram CD 3300
5141, 5142, 5143 5144, 5145Service ManualSilver Log in
