BeoGram 3500
BeoGram 3500
Another incarnation of the lightweight B&O tangential turntable, this one was designed to match the Beomaster 3500 with it's 'battleship grey' trim on the dust cover and was supplied with an MMC4 cartridge. A RIAA was built into this model.
Type Number: [wptb id=51804]
Designer: Jacob Jensen
Colour / Finish: Grey, Black
Cartridge Type: MMC4
Wow and flutter, DIN 80 dB
Rumble DIN unweighted > 55 dB
Speeds
33 - 45 rpm.
Speed deviation < +/- 0.2 %
Power supply
5976: 220V
5977: 120V
5978: 100V
Power consumption < 10 watts
Dimensions W x H x D 42 x 7.5 x 32.5 cm
Weight 5.3 kg
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoGram 3500
5976,5977,5978,5979Service ManualSilver Log in
