BeoGram 3000 (1985)
BeoGram 3000 (1985)
Beogram 3000 was a specially designed tangential record deck with a lightweight tone arm featuring the patented suspension system - Optimum Pivot Point - which prevented internal vibrations from interfering with sound reproductions. Beogram 3000 was a specially designed tangential record deck wit [...]
Beogram 3000 had an MMC 4 pick up for optimum sound and minimal record wear. A record sensor automatically record size and with it, the correct speed. The platter reduces static electricity and thereby dust in the grooves, and the pendulum suspension made Beogram 3000 'danceproof'. The search system worked both forwards and backwards and the new Active Light system was all automatic, giving you light when you needed it, for searching and changing your records etc.. A repeat function allowed you to play the same record up to 7 times in a row.
Beogram 3000 was designed to be used within Beosystem 3000. Beogram 3000 does not have a built in RIAA amplifier and relies on this being in the receiver used with it. Beomaster 3000 - which this deck was designed to work with - has the RIAA built in as do almost every receiver before this time, including the Beomaster 8000. Later equipment such as the Beomaster 7000 and Beomaster 3500 and Beomaster 4500 transferred the RIAA to the record player as this allowed a longer cable to be fitted to the record player and gave better siting options.
Type Number: 5901, 5903, 5905
Release Date: 1985, 1986, 1987
Designer: Jacob Jensen
Colour / Finish: Grey and Black
Cartridge Type: MMC4
Speeds: 33 - 45 rpm
Speed deviation: < +/- 0.2
Wow and flutter, DIN 80 dB
Rumble DIN unweighted > 55 dB
Power supply:
5901: 220-240 V
5903: 120 V
5904: 110 V
5905: 240 V
Power consumption: < 10 W
Dimensions: W x H x D 42 x 7.5 x 32.5cm
Weight 5.3 kg
Link compatibility: Data Link
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoGram 3000 (1985)
5901,5903,5904,5905 Service ManualSilver Log in
BeoGram 3000 (1985)
5901,5903,5904,5905Service ManualSilver Log in
