BeoGram 3000 (1972)
BeoGram 3000 (1972)
Beogram 3000 was an automatic high-fidelity stereo record-player with specifications which easily complemented those of Beomaster 3000-2. It was fitted with an SP 12A pick-up cartridge which had an elliptical naked diamond stylus, with a stylus pressure of 1,2g. Frequency range was 20 - 25000 Hz [...]
It was fitted with an SP 12A pick-up cartridge which had an elliptical naked diamond stylus, with a stylus pressure of 1,2g. Frequency range was 20 - 25000 Hz ±3 dB and distortion was lower than 1%. Wow and flutter was less than ±0.09% and rumble was better than 62dB. Beogram 3000 was easy to operate: you simply selected the size of record you intend to play - 7", 10" or 12" - and press a button. The record-player automatically selected the record speed, 33 or 45 rpm, and lowered the pick-up into the first groove.
When the record ended, the pick-up arm lifted up, returned to its resting position and the turntable switched off. The turntable and pickup arm had a pendulum suspension which made the record-player insensitive to vibrations. The deep furrows in the turntable made it easy to pick up records. A hinged dust lid was fitted; it could be set at any angle up to around 60 degrees or completely removed by a simple sliding action.
Type Number: 5210, 5211, 5228, 5231, 5241
Release Date: 1972, 1973, 1974, 1975
Designer: Jacob Jensen
Colour / Finish: Rosewood, Teak
Cartridge Type: SP12A
Speeds: 33,3 and 45 rpm
Rumble Better than 60 dB (DIN B)
Wow and flutter +/- 0.06% RMS
Vernier adjustment 6%
Antiskating device: built-in
Stylus pressure adjustment 0 – 3.5 g (ponds)
Pickup: SP 12 A
Stylus pressure 1.2 g (pond)
Output: 5 mV – 1000 Hz / 47 k ohms
Voltage: 110 – 130 / 220 – 240 V AC
Power consumption: 10 W
Dimensions W x H x D 44 x 11.5 x 33cm
Accessories: Pre-amplifier Type 8905306
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoGram 3000 (1972)
5228Instruction BookSilver Log in
