The top of the range of the radial turntables at this time, it was differentiated only by a different pick up and a weighted platter from the lesser models. As with all this range, fully automatic and cleverly designed to look even lower than it actually was!
BeoGram 1900
Sound system Stereo, matrix
Speeds: 33 – 45 rpm
Tonearm: radial
Automatic pickup movement: Yes
Automatic speed selection: Yes
Output: 2 x 0.6 mV
Wow and flutter DIN: < +/- 0.07 %
Rumble DIN unweighted: > 42 dB
Rumble DIN weighted: > 62 dB
Speed deviation: < 0.1 %
Speed control range: > 3 %
Dial for speed stroboscope: 120mm
Pick-up cartridge: MMC 4000
Recommended stylus pressure: 1 g
Stylus pressure range: 0 – 2.5 g
Stylus: elliptical naked diamond
Radius of curvature: 5 x 17 µm
Frequency range: 20 – 25,000 Hz +/- 2.5 dB Tracking error < 0.126 / cm°
Lift system Mechanical
Antiskating Inclined channelling inside bearing
Motor Asynchronous
Drive system Idler wheel and belt
Turntable 30cm/1 kg
Power supply: 110 – 220 V
Power consumption: 10 W
Dimensions W x H x D: 44 x 9 x 33cm
Weight 6 kg
Downloads & Manuals
Documents & Downloads
Document | Type No. | Type | Required | Action |
BeoGram 1900 | 5705 | Service Manual | Silver | Log in |
Photo Gallery
No gallery images.
