BeoGram 1800 (1968)
BeoGram 1800 (1968)
This was a rare and interesting model. It boasted a new arm and motor compared to the Beogram 1000 but retained quite a lot of the design and the uninspired rubber mat. It also had a most unusual dust cover with a metal surround with only the top panel being transparent. This design was to be see [...]
It also had a most unusual dust cover with a metal surround with only the top panel being transparent. This design was to be seen also in the prototype Beogram 6000 but not in any production model.
Type Number: 5213
Release Date: 1968, 1969, 1970, 1971, 1972
Designer: Jacob Jensen
Colour / Finish: Teak, Rosewood, White
Cartridge Type: SP10A
Speeds: 45 and 33,3
Rumble: better than 55 dB (DIN B.)
Wow and flutter: +/- 0.15 peak value
Amplifier:
Max. 3.5 V RMS = 10 V pp (corresponding to 58 cm/sec./1000 Hz)
Pickup:
SP 10 A type 5425
Stylus pressure 1 g (2 g max)
Output:
5 mV - 1000 Hz / 47 k ohms
Voltage:
110 - 220 volts AC
Power consumption 22 W
Dimensions W x H x D: 43.8 x 13.2 x 32.3 cm
Weight 6.5 kg
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoGram 1800 (1968)
5213Service ManualSilver Log in
