BeoGram 1600
BeoGram 1600
Beogram 1600 was manufactured primarily for the US and French markets; therefore in the overall scheme of things, there weren’t many of these around.  A fairly basic machine, Beogram 1600 was designed for use within the Beomaster 1600 and Beocord 1600 system when it complemented these other products [...]
Beogram 1600 was manufactured primarily for the US and French markets; therefore in the overall scheme of things, there weren’t many of these around.  A fairly basic machine, Beogram 1600 was designed for use within the Beomaster 1600 and Beocord 1600 system when it complemented these other products nicely.  It fitted with the MMC 20E combined cartridge/stylus.
Type Number: 5712, 5713
Release Date: 1978, 1979, 1980, 1981, 1982, 1983, 1984, 1985, 1986
Designer: Jacob Jensen
Colour / Finish: Rosewood, Teak, White
Cartridge Type: MMC20E
Speeds / control range 33 – 45 rpm. / > +/- 3 %
Wow and flutter, DIN 62 dB
Rumble unweighted > 42 dB
Motor / drive system: Servo-controlled DC / Belt
Pickup: MMC 20 E
Recommended tracking force 15 mN / 1.5 g
Power supply:
5712: 120V
5713: 220V
Power consumption 8 W
Dimensions W x H x D / Weight 44.5 x 8.9 x 33 cm / 6 kg
Type: US 5712 (1977 – Dec 1978)
Pickups: MMC 20 E
Power supply: 120 V
Dimensions: W x H x D / Weight 44.5 x 8.9 x 33 cm / 6 kg
Downloads & Manuals
