BeoGram 1202
BeoGram 1202
The Beogram 1202, although looking very similar to the earlier Beogram 1200, was an entirely new record deck and was far more sophisticated than the earlier model. It continued with the multi-peg system of record support - possibly the decks greatest weakness - and also lacked the hinged lid of the [...]
The Beogram 1202, although looking very similar to the earlier Beogram 1200, was an entirely new record deck and was far more sophisticated than the earlier model. It continued with the multi-peg system of record support - possibly the decks greatest weakness - and also lacked the hinged lid of the Beogram 3000 to which it was otherwise practically identical. This is the 1200 type deck to own!
The operating system was simplified from the 1200 though the same arm and motor were used. The suspension was however far better - imagine this deck as a Beogram 3000 with a silly platter and a less useful lid and you will not be far wrong. It is however the best of the 'peg platter' decks. Very collectible.
Type Number: 5237
Release Date: 1972, 1973, 1974
Designer: Jacob Jensen
Colour / Finish: Rosewood, Teak, White
Speeds: 33,3 and 45 rpm
Rumble Better than 60 dB (DIN B)
Wow and flutter Better than +/- 0.15 % peak value (DIN), corresponding to +/- 0.06 % rms
Vernier adjustment 6 %
Antiskating: built-in
Stylus presurre adjustment 0 – 3.5 g (ponds)
Pickup SP 14 A
Stylus pressure 2 g (p)
Voltage: 110 – 130 / 220 – 240 V AC
Power consumption 10 W
Output: 5 mV – 1000 Hz / 47 kohms
Dimensions W x H x D 44 x 12 x 33cm
Weight 9 kg
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoGram 1202
5237Instruction BookSilver Log in
