The Beogram 1001 was a slightly updated Beogram 1000. The major change which you may notice is the lack of the name on the front of the cabinet. You may then notice the lack of a 78 rpm setting and finally the cartridge changed to the SP14 rather than the SP6/7. Performance was however just the same - surprisingly good but poor isolation from external vibration. The lid was just as useless as before and did not allow it to be left on during playback.
BeoGram 1001
The Beogram 1001 was a slightly updated Beogram 1000. The major change which you may notice is the lack of the name on the front of the cabinet. You may then notice the lack of a 78 rpm setting and finally the cartridge changed to the SP14 rather than the SP6/7. Performance was however just the same [...]
Speeds: 45 and 33 rpm., with provision for vernier adjustment of speed
Rumble Better than 55 dB (DIN B)
Wow and flutter +/- 0.15 % peak value
Pickup arm: ST/L 15°
Pickup SP 14 A
Recommended tracking force 1.5 – 2.5g
Voltage: 220 volts AC
Power consumption 10 W
Dimensions W x H x D 36 x 11.5 (approx. 12.5cm with dust cover) x 31cm
Weight 6 kg
Downloads & Manuals
Photo Gallery
No gallery images.
